Date/Time: Sat, 08 Feb 2025 10:47:56 +0000
Trade Activity when running two instances
View Count: 530
[2020-07-08 15:47:45] |
User98657 - Posts: 331 |
I'm running two separate instances of SC. When i view my Trade Activity from either, am i seeing the same data? It seems as though i am, and that makes me very happy if that is the case. |
[2020-07-08 19:20:24] |
Very likely yes since you are using the Sierra Chart Order Routing Service. However, if there are any missing order fills you can always re-download them: Trade Activity Log: Automatically Inserting Missing Order Fills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
