Date/Time: Sat, 08 Feb 2025 10:39:37 +0000
Market Depth Historical Shows Incorrect
View Count: 620
[2020-07-08 14:01:31]
User432142 - Posts: 44
pls check attached files
when l use volume based chart, market depth shows incorrect. specially when high volumes occur.
6th of july 8:38 am CDT (UTC -5)
imageone second candle chart.jpg / V - Attached On 2020-07-08 13:56:46 UTC - Size: 132.65 KB - 318 views
imagevolume based chart.jpg / V - Attached On 2020-07-08 13:56:53 UTC - Size: 94.97 KB - 333 views
[2020-07-08 19:09:58]
We do not understand what you are trying to show us. Can you give us more specific information on what you think is occurring.
[2020-07-09 00:07:40]
when you check screenshot of volume based chart,it shows level 2 data which pointed by arrow below of price is ask level 2 data instead of bid level 2 data
[2020-07-09 18:49:42]
Turn off the option in the Market Depth Historical Graph for Extend Last Known Depth. Then see what the data looks like. Most likely you are missing data during that time and therefore it was extending the last known depth forward. Refer to the information here:
Market Depth Historical Graph: Extend Last Known Depth
