Date/Time: Sat, 08 Feb 2025 11:20:31 +0000
[User Discussion] - custom alert sound
View Count: 951
[2020-07-08 11:41:52] |
Robert Wojczak - Posts: 147 |
How do I import a custom alert sound. Thank You
[2020-07-08 16:26:01] |
Sawtooth - Posts: 4173 |
Alert sounds are in your SierraChart \AlertSounds folder. Move your custom sound file there. It must be a .wav file. You can then select it when choosing the sound for your alert. https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#Tab_General3 |
[2020-07-08 17:41:53] |
Thank you but how I move it to the sounds folder?
[2020-07-08 18:36:41] |
In Win10, use File Explorer.In Win7, use Windows Explorer. |
