Date/Time: Sat, 08 Feb 2025 11:13:24 +0000
Rithmic
View Count: 517
[2020-07-08 09:54:32] |
User655179 - Posts: 1 |
I use Sierra chart - Rithmic; I work on two computers (on house and in work), everything works on the first computer (in work) and it doesn't work on the second computer (in house) because Sierra doesn't see these files: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward I downloaded the zip file, but because I didn't have the RIM folder, I created it and pasted the downloaded files. Unfortunately, Sierra does not see this bridge at all when he turned on the chart, there is no reaction and connection with the bridge. On my computer on work folder Rim existed, so I passed the file and everything works.
[2020-07-08 10:06:56] |
Refer to: Regarding Rithmic (Our Final Post on this Subject) Read through the first post in its entirety. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
