Date/Time: Sat, 08 Feb 2025 11:53:42 +0000
Stock Symbols
View Count: 846
[2020-07-07 20:05:33] |
VerbalJournal - Posts: 5 |
I went through the process for NYSE/Nasdaq data. Is there something I have to do to pull up individual stocks? Is there another payment?
[2020-07-08 06:45:51] |
You will need to use the Sierra Chart Exchange Data Feed for this data. Full documentation and instructions are here: Sierra Chart Exchange Data Feed Also you are running an older version of Sierra Chart. Update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-09 18:37:23] |
Is it possible to use 2 data services at once? ie - one data vendor for futures and the other for stocks? Second question. I remember filling how forms for individual stock data for Sierra. Does it show on my account? I was assuming after going through the checklist with those forms that maybe I needed to do something to enable it. |
[2020-07-09 20:32:27] |
Yes. Refer to: Using Multiple Data and Trading Services at the Same Time The agreements related to the US equities data feed are on this page: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-09 20:32:34
