Date/Time: Sat, 08 Feb 2025 10:48:05 +0000
order Pending in SC but not in AMP
View Count: 597
[2020-07-07 17:25:47] |
JCGO - Posts: 10 |
Hello, I have a pending order in SC but it is not allowed to be canceled in any way, this is the log message: Order cancellation failed | SC Futures Order Routing / Data order update (Order cancel reject). Info: Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Text: Parent order. Tag: JCGO.twconfig. Internal Order ID: 160. Service Order ID: 1855351. Symbol: MESU20_FUT_CME. Account: AC130494 | 2020-07-07 12: 22: 25.969 * In AMP informs me we do not see any work order but you see in your chart, contact support bord SC. I appreciate your help. |
[2020-07-07 17:47:57] |
Sierra_Chart Engineering - Posts: 18338 |
This would indicate the order was not acknowledged by TT and was not processed by TT. This would be a TT issue. We will make sure that order is cleared at the end of the day.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-07 17:48:18
[2020-07-07 18:10:26] |
JCGO - Posts: 10 |
Ok, if the price reaches the pending order is activated?, I am concerned that there is no stop and can not be put?
Date Time Of Last Edit: 2020-07-07 18:10:44
[2020-07-07 18:16:29] |
In all of our experience when this has happened a few times in the past, the order just was never processed by TT. It is a nonworking order.
[2020-07-07 21:55:21] |
This order is now cleared.
