Date/Time: Sat, 08 Feb 2025 11:21:13 +0000
Chart trade window does not open
View Count: 1038
[2020-07-07 14:01:44]
User548030 - Posts: 25
Since upgrading to version 2131, the chart trade window will not open. I can get it to attach to the chart, but it won't display if it's de-attached. I usually have it de-attached from the chart on another display. This issue applies to Open GL enabled and disabled.
[2020-07-07 15:18:30]
It sounds like the Trade Window is set to an area outside the monitor view. Refer to this menu item to reset its position:
Chart Menu: Reset Child Window (Chart menu)
