Date/Time: Sat, 08 Feb 2025 10:56:10 +0000
Parallel Rays jump after being cut
View Count: 589
[2020-07-07 10:08:06]
PerfectPA - Posts: 3
Hi SC-Team!
Your software is absolutely amazing and I love it! There is only one thing which is not perfect and it bothers me for a long time.
I use 'Parallel Lines Tool' a lot. When I use 'Cut Drawing Here', the lines move a little bit for no apparent reason ('Auto Snaps' are off). This makes long Channels imprecise.
Example: Draw 45° Line >> cut it >> Line has now 42.93°
What's the problem here?
[2020-07-08 10:11:15]
Uncheck this option:
Chart Settings: Adjust Tool Values to Tick Size (Chart >> Chart Settings >> Chart Drawing menu)
