Date/Time: Sat, 08 Feb 2025 11:14:31 +0000
Not connecting to Ryhtmic Paper trading
View Count: 504
[2020-07-07 09:14:16] |
User232917 - Posts: 3 |
Hi, I am follwing a course now with Axia Future and I have to connect to Rithmic and Paper trading server, but it does not work. I tried to re install the software because on the Instlattion guideline from Axia it is recommending to check the box (optionnal component) as well, so I did check it but an error happens when doing it. So hopefully you can help me. Thanks Alexandre |
[2020-07-07 15:22:44] |
Refer to: Regarding Rithmic (Our Final Post on this Subject) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
