Date/Time: Mon, 25 Nov 2024 08:26:27 +0000
Deleting Drawing Objects
View Count: 3260
[2014-01-28 22:41:16]
Profile Trader - Posts: 174
I use to be able to select a horizontal line and then hit delete on my keyboard and it would delete it. Now it will not do that. I have Support Left Click to select chart drawings checked in global/tool settings.
Is there something else I need to setup for this too happen again?
Thanks,
Doug
[2014-01-29 06:15:46]
User40117 - Posts: 56
i'm new to SC and also was a bit suprised this is not a standard feature.
You can double click right mouse however...
But i find it also a bit strange that you call it Tools that are drawn and then define Erase Drawing (i'd expect Tool). I would expect Erase drawing to erase all tools...
But that might be because i have a CAD software (developer) background.
Some other suggestions:
- regarding interactive scale / move, instead of right click and menu it would be nice to be able to f.e. scale as a standard left click en f.e. Shift + left click for move...
- maybe hire a DTP'er to design some decent icon's and to clean up the dialogs, i know it's mainly the inside that count's, and it is beautiful, but doesn't your wife also look nicer with some little make-up on ? And i have to spend much more hours watching SC then my wife ;-)
Keep up the good work !
[2014-01-29 06:23:03]
You need to have either the Pointer or Chart Values tool to be able to select an existing drawing.
A tool draws a drawing. So there is the Tool and then the resulting tool drawing.
What you write something on a piece of paper with a pen or pencil, do you call the writing a pen or pencil. Of course not.
Date Time Of Last Edit: 2014-01-29 06:23:32
[2014-01-29 07:27:31]
We know the pointer is needed, but pressing delete does not seem to work (anymore)...
English is not my native language, but to me a drawing is a combination of lines, text, rays, rectangle, ellips ... (or entities).
Just making suggestions (scaling, bodyworks) to improve your already great product tho... sorry about that
[2014-01-29 09:13:03]
tobi - Posts: 351
Not sure what you are doing wrong!? Working fine here (SC version 1086) as it always did.
Attached is a screenshot of my Tools Settings.
Other ideas:
- Are you using the backspace instead of the delete button? Backspace doesn't work.
- Which delete button on the keyboard are you using? If using the one in the Numpad, make sure that Num Lock is NOT enabled.
imageTool Settings.png / V - Attached On 2014-01-29 09:05:41 UTC - Size: 35.32 KB - 521 views
[2014-01-29 09:18:30]
Neither of the DEL buttons seem to work (v1086). I can double click right however to erase.
I did not change any settings regarding selection or tools or whatever.
[2014-01-29 10:05:04]
Go to Global Settings >>Customize Keyboard Shortcuts.
Remove the Delete key assignment from Spreadsheet >> Clear Selection.
