Date/Time: Mon, 25 Nov 2024 08:33:00 +0000
Chart time
View Count: 1048
[2014-01-28 21:24:26] |
robna - Posts: 18 |
Time is right on my PC but on the chart it is way fast all the way across the bottom.
[2014-01-28 21:25:26] |
Refer to this help topic: Http://www.sierrachart.com/index.php?l=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 21:25:34
