Date/Time: Sat, 08 Feb 2025 08:14:05 +0000
[User Discussion] - Replay Feature question
View Count: 547
[2020-07-06 16:28:37]
User518104 - Posts: 1
It seems using the replay feature option, the ticks are not updated every second (for example it seems to be working fine second by second for 5 seconds and then it will skip 1 second every once in a while).. For example, it will updated the ticks second by second for 9:45:01, 9:45:02, 9:45:03 and then freeze and skip to 9:45:06.
Is there a way to fix this?
