Date/Time: Mon, 25 Nov 2024 08:29:10 +0000
Number Bars
View Count: 1104
[2014-01-28 19:30:56] |
Profile Trader - Posts: 174 |
Is there a way to make one of the columns much thinner then the other? I would like to show in the first column where 75% or more volume has taken place and on the second the bid ask. In doing this I waste alot of space for the first column that could be just a thin bar next to the bid ask text. I am only interested in the background coloring of column one. Also is there a way to separate what color is used for text and what color is used for background within a column. makes it hard to use different variables when they get colored the same... ie a colored box green will not reflect green text inside it. Thanks, Doug |
[2014-01-28 21:12:43] |
1. No. 2. Only if the Column # Text Coloring Method is set to None. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 21:12:58
