Date/Time: Mon, 10 Feb 2025 01:32:49 +0000
Stair steps not showing on the chart
View Count: 685
[2020-07-06 12:34:46]
User414460 - Posts: 5
Hi guys, do you know why the stair steps are not showing on my chart?
imageCapture.PNG / V - Attached On 2020-07-06 12:33:28 UTC - Size: 29.4 KB - 235 views
[2020-07-06 18:42:10]
We really are not sure what you are referring to. This request is not clear for us.
[2020-07-07 13:12:36]
I attached a picture to this message with a stair step chart.. In my case (see the picture attached to my first message) I can see only two parallel lines...
imageCapture 1.PNG / V - Attached On 2020-07-07 13:10:59 UTC - Size: 53.8 KB - 243 views
[2020-08-20 10:08:24]
6Jack6Jones6 - Posts: 17
How Did the issue get solved for the stair step get solved. I'm having the same issue. I only see two parallel lines.
[2020-08-20 10:24:17]
Ackin - Posts: 1865
6Jack6Jones6 )
In general, Drawstyle as a graphic element is fine on version 2154. It would be good to write in which study you are using it, because the problem will be there (you will have wrong or no values to display in that study).
[2020-08-20 11:02:26]
Im Using Bid & Ask Prices study.
