Date/Time: Sat, 08 Feb 2025 08:30:49 +0000
[Programming Help] - Volume By Price enclosing box with keyboard
View Count: 780
[2020-07-04 16:10:17] |
QnReally - Posts: 181 |
Hi, In the past you added functionality to update the profile volume graphic as we enlarge/contract the enclosing box with the mouse, dynamically with each mouse move. That has really been helpful. Now, to enhance the usability of that feature further I was wondering if you could add functionality to do the same with the keyboard. Specifically, once the drawing enclosure is selected on a Drawn Volume Profile, I would like to be able to adjust the left edge as well as the right edge, both to the left or the right. If only one edge is feasible in the short-term, I would prefer the ability to adjust the right edge first. If this is not doable in the near to medium term, I would also be interested in knowing how to do this myself with ACSIL if that is feasible. This helps while studying the charts to see where the traded volume was in various swings. The mouse method is really useful also but due to the need to precisely find the enclosing box and to enlarge the box one bar at a time, there is fatigue associated with it when you want to go through a lot of days worth of charts at a time. Thanks for the support. |
