Date/Time: Tue, 22 Sep 2026 10:01:51 +0000
accounts
View Count: 815
[2020-07-03 21:08:19]
User192647 - Posts: 7
i'm presently and will continue using Sierra Charts
i have an account with AMP Futures
i will be opening another brokerage acc't and will be using Sierra Charts
presently i have a descent setup on the [ Trade Doms] on the Sierra Charts used for AMP Futures
is there a way to add another account to Sierra Charts
is there a way to same or duplicate the [ trade dom ] w/o going thru the hassle of re-setup
[2020-07-07 08:11:29]
We do not have enough information to understand exactly what you want to do, but if you are opening another account with a different brokerage, then you would have to have a Direct Sierra Chart Account in order to use Sierra Chart with that other account. The account you have with AMP only allows you to connect to your AMP account. Refer to the information here:
As to keeping your information, again, it depends on the setup you end up as to how you do this, but if you have a separate brokerage account, then you would need a separate installation of Sierra Chart. You can then copy the files ffrom your current installation to the new installation to use with the other trading service in order to start with the same setups. Refer to the information here:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
