Date/Time: Sat, 08 Feb 2025 08:01:35 +0000
Trade Order Window
View Count: 550
[2020-07-03 02:51:46]
User745789 - Posts: 358
Per the attached image, could you pls help me understand these entries. These are obviously not real fills:
- The mkt has not even traded at those levels in the session.
- There is no Open/Close field entry
- There is no value for the "Text Tag" field, unlike for for real orders
- I have only executed two trades today
I had a working bid at 22100, with attached orders, it was cancelled. The rest of the prices of these "fills" mean nothing to my activity today.
I know you do not support CQG, but this is for MJNK.OSE, which I would trade via SC if possible.
Date Time Of Last Edit: 2020-07-03 02:53:58
image2020-07-03 11_38_43-Trade Orders.png / V - Attached On 2020-07-03 02:48:42 UTC - Size: 39.65 KB - 250 views
[2020-07-03 07:49:03]
You need to contact your broker for help. This is completely outside the scope of our support. This should not even be posted here. Probably you are seeing fills from the past. The Date-Times you see are not necessarily accurate in relation to the timing of those fills.
Date Time Of Last Edit: 2020-07-03 07:50:05
