Date/Time: Sun, 01 Nov 2026 00:07:40 +0000
Connecting once a month verification
View Count: 1488
[2020-07-02 20:32:16]
User143517 - Posts: 68
Hi there,
I have just activated Denali Exchange Data Feed and the Exchange Data, but received that "Connecting once a month..." messsage.
Also, my TT account assignment has been completed and set SierraChartFIX_2.
With that, I have three questions:
1)Do I still need to take this action of connecting once a month for further verification of a funded trading account?
2)If yes. I have been using SC Data-All Services[data] with Trade Simulation mode one. Should I just disable trade simulation mode, wait for some seconds and enable again? Would that just be enough for verifcation?
3)If not, which connection should I use for that verification?
Thanks,
[2020-07-03 09:30:24]
First, since you are using the Sierra Chart Order Routing Service, you need to set your Data/Trade Service Settings to SC Futures Order Routing/Data. Make sure you finish going through the Setup Instructions for the Sierra Chart Order Routing Service starting at step #9 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
1. If you do the above, then you are automatically connecting to your trading account every time you use Sierra Chart, so you do not need to do anything special to connect every month, it is automatically taken care of for you.
2. You do not need to worry about this.
3. You do not need to worry about this.
