Date/Time: Sat, 08 Feb 2025 08:28:18 +0000
No Route for Eurex
View Count: 607
[2020-07-02 16:35:43]
User551971 - Posts: 34
Hi, i get the message Order rejected route does not exist ... (see Attachment)
Who has to fix it ? You or my Broker Dorman ?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=40952
[2020-07-02 17:15:01]
It is our understanding that Dorman does not support trading EUREX with the Sierra Chart Order Routing Service.
You will need to use CQG for EUREX or use a different clearing firm that supports EUREX over TT.
We are aware that AMP and Stage 5 support trading EUREX with the SC Order Routing. You can also check for other brokers on the list in Step 2 of the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
