Date/Time: Wed, 09 Sep 2026 19:44:20 +0000
Call External DLL
View Count: 1213
[2020-07-02 12:01:25]
gfx2trade - Posts: 48
Hi SC team,
In my current trading system, I'd like to call an exsiting SC study to get back the indicator value, rather than having to program this study in my cpp file.
Is there any call function available,
Also for my own existing indicators built in my cpp file, is there any way to specify a time frame to calculate when different from the chart time frame the system is running on ?
Thks.
B.
Gfx
[2020-07-04 16:08:54]
ForgivingComputers.com - Posts: 1238
You can read the outputs (subgraphs) of any study by using sc.GetStudyArray: ACSIL Interface Members - Functions: sc.GetStudyArray()
You would need another (source) chart with a different time frame and your existing indicators, then you can use sc.GetStudyArrayFromChart() on the destination chart.
[2020-07-06 00:31:58]
Refer to:
Referencing Other Time Frames and Symbols When Using the ACSIL
ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function
