Date/Time: Sat, 08 Feb 2025 10:59:35 +0000
[User Discussion] - Manual entry of Small Exchange for IB
View Count: 893
[2020-07-02 09:31:05] |
rlotz1 - Posts: 11 |
Has anyone figured out how to manually enter the symbols for the small exchange for IB users, I haven't had any luck.Thanks.
[2020-07-08 02:20:21] |
This should not be difficult. Follow the futures format here: Interactive Brokers Symbols: Futures Format Be sure to include these components of the symbol as well: -[optional currency code]-[optional multiplier]
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-08 02:20:43
