Date/Time: Sat, 08 Feb 2025 07:52:28 +0000
broker
View Count: 747
[2020-07-01 23:21:36] |
User435059 - Posts: 14 |
hello , i just wonder if anything change ? best is TT ? second Cqg and nothing else ? no IB ? have you establish good connection with Philips capital ? or or only Advantage Futures ? |
[2020-07-02 08:05:31] |
If you are trading the CME group of markets overall the Sierra Chart order routing service is very recommended: Sierra Chart / Trading Technologies Futures Order Routing Service We do not want to say that TT is best because they are not perfect. Although this is what we are using now for the order routing until we have our own direct order routing to the exchanges. Both Phillips and Advantage both support the Sierra Chart order routing service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 14:15:16] |
Ok but you use to have good price on TT with Advantage , how about Philips did you talk to them ? if i remember this was pending
[2020-07-02 18:34:10] |
SC Support - Posts: 1930 |
Hi User435059, if you are saying that you wish to pose your questions directly to Phillip Capital, we can email you their contact information.
[2020-07-02 19:14:25] |
O no i just wonder if anything change , it is possible to get delali professional data only for MYM , MY, ZN .
[2020-07-02 22:32:28] |
If you activate exchange options that are designated as "For professionals and users without a trading account", then you will not need to have a trading account with a supported trading service or broker.
Sierra Chart Support Date Time Of Last Edit: 2020-07-02 22:32:49
