Date/Time: Sat, 08 Feb 2025 08:17:50 +0000
Sort Statistics
View Count: 531
[2020-07-01 22:13:45] |
User993067 - Posts: 157 |
1.Is there a setting that will allow me to sort the statistics summary by strategy (.twconfig files) these are listed under notes in trade list but I cannot see summary for each strategy. 2. Is there a setting for the replay feature that will visually display my fills on the trade dom as they occurred...I would like to analyze my fills for location and this would be ideal. thx |
[2020-07-02 08:07:41] |
1. We are not understanding this. 2. Yes this is now supported in the latest version. Update: Software Download: Fast Update Refer to: Replaying Charts: Replay and Trading And the following section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-02 08:07:49
