Date/Time: Sat, 08 Feb 2025 05:57:00 +0000
DOM graph on chart - alignment of VbP
View Count: 724
[2020-07-01 21:16:52] |
Dean Roberts - Posts: 79 |
Hi Support I hope you are well and keeping safe? Question please; I'm adding the DOM graph option onto a footprint chart but it's then pushing the alignment of my VbP right out to the right (please see attached). Is there any setting that will allow for the VbP to move further over toward the right/DOM graph please? This also happens even without the DOM graph as you can see from the second image - is it possible to change the scaling? I've attached and image with the scales reset, as instructed, but it's not usable like that. Many thanks http://www.sierrachart.com/image.php?Image=1593629186986.png http://www.sierrachart.com/image.php?Image=1593629514469.png http://www.sierrachart.com/image.php?Image=1593629376734.png Dean |
