Date/Time: Sat, 08 Feb 2025 07:53:02 +0000
not placing any order with a very simple autotrading system
View Count: 663
[2020-07-01 18:49:38] |
User275592 - Posts: 97 |
Hi, I am discovering the auto trading system and i tried first a very simple one based on Moving Average crossing (i am NOT trading in real with this system !) I am using 2 moving average and the study Subgraph Crossover I set autotrading global "on", autotrading Chart "on" and send trade order to trade service "on" When I run this system with real time data, the points "on low" and points "on high" are plotted when the crossover condition with line 1 and line 2 is verified BUT no order is sent. That is my problem ... Thank you for your help Renaud Date Time Of Last Edit: 2020-07-01 18:50:21
[2020-07-02 07:43:52] |
This is the problem: and send trade order to trade service "on"
Refer to: Automated Trading Management: SendOrdersToTradeService Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 14:48:04] |
so sorry, i red the doc three times :-( Thank you for your help Renaud |
[2020-07-02 17:12:10] |
Refer to the information here for that Input: Trading System - Study Subgraph Crossover You will see that for Simulation Mode that option needs to be set to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 17:44:10] |
Yes, i am ok I was sorry to disturb you for an information mentionned in the documentation Thank you for your help (i am not fluent in english) |
