Date/Time: Mon, 25 Nov 2024 09:27:53 +0000
Cannot edit a Remote Chart Data File. Edit the data in the source copy of Sierra Chart.
View Count: 1057
[2014-01-28 13:31:55] |
User16114 - Posts: 153 |
What is the best way to refresh chart data in the destination instance of SC when there is no chart open in the source (remote) instance of SC. Getting the following message in the message log "Cannot edit a Remote Chart Data File. Edit the data in the source copy of Sierra Chart." when selecting "Edit/Download Data - Intraday Chart" in the destination chart right click menu. Using two instances of SC. First instance IQFeed data and second AMP/TTNet. Thanks! |
[2014-01-28 17:47:29] |
There is no way to do this. You must do this only in the source instance and have to open the chart there.
