Date/Time: Sat, 08 Feb 2025 06:10:53 +0000
ZSQ shows wrong Data?
View Count: 603
[2020-07-01 16:47:37] |
User551647 - Posts: 23 |
http://www.sierrachart.com/image.php?Image=1593621705622.png Hi, I have the following problem. I am loading the Soybeans August contract. In the picture you can see that the highs are at 898. But if you check the CME Page and other chart programms, you can see that the high was around 891. So why do I see bars at 898? What did I do wrong? Many thanks in advance! |
[2020-07-01 19:03:21] |
The data in the chart must be correct. But also make sure you know what contract month you are looking at for each bar: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
