Date/Time: Sat, 08 Feb 2025 06:06:01 +0000
Eurex over Denali Feed
View Count: 736
[2020-07-01 14:10:54] |
User551971 - Posts: 34 |
Will there be Eurex data on Denali in the foreseeable future? Your current solution via barchart works but is very expensive especially if you have Denali with you.
[2020-07-01 19:41:45] |
Probably not until the end of the year. To reduce the cost of what you are using now, You need to change to the 20 symbol limit for the Sierra Chart Exchange Data Feed. You can do this here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures And you get a 12 USD credit per month when using both data feeds together: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing So the cost is only about $12 a month more. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-01 19:56:47] |
ok thanks for it. I change the Symbol limit to 20 but in my cost overview ther arwe more than $12. Anything else to do ? |
Attachment Deleted. ![]() |
