Date/Time: Fri, 04 Apr 2025 03:25:27 +0000
ACSIL - OpenGL - SC sample Code
View Count: 919
[2020-06-30 22:07:33] |
ejtrader - Posts: 688 |
SC Team - You have provided a sample GDI code(GDIExample.cpp). Could it be possible to provide a sample OpenGL code as well - when your time permits? As OpenGL is stable now - would like to switch from GDI to OpenGL. PS: Please don't mark it as programming help - just looking for a sample code in OpenGL that would interact with SC and would be able to expand further on top it. thanks |
[2020-07-01 07:15:13] |
OpenGL is not supported for ACSIL and it is not currently planned.
