Date/Time: Fri, 28 Feb 2025 18:37:59 +0000
Drawing a rectangle that cross regions
View Count: 866
[2020-06-30 18:08:07]
User837393 - Posts: 143
I'd like to draw a vertical rectangle (yes, I know ... Tools>>Rectangle), but that cross regions. Let say I'd like to highlight an oversold RSI situation with a the main graph and draw one rectangle to illustrate the whole scenario.
Right now, when I draw the rectangle it limit itself to the main graph and I need to repeat the same procedure for the region below.
Isn't there away to draw one sigle rectangle accros regions ?
Best regards
Date Time Of Last Edit: 2020-06-30 18:08:34
[2020-06-30 18:31:20]
No this is not supported.
[2021-08-31 14:21:12]
User246553 - Posts: 33
any update on this? was also searching for this feature.
[2021-08-31 16:37:50]
John - SC Support - Posts: 38280
There has not been any change to the functionality to allow rectangles to cross regions.
[2021-08-31 19:13:19]
Ackin - Posts: 1865
in each region: Insert a copy of the study: Color bar based on alert conditions with SG drawstyle set as "Background"
Date Time Of Last Edit: 2021-08-31 19:13:42
