Date/Time: Mon, 25 Nov 2024 09:50:21 +0000
connection problem
View Count: 1362
[2014-01-28 07:35:21] |
pavel.matousek80 - Posts: 3 |
Hello, I try to connect to OEC with SC, but I have only this respons. This message I have from installing new version 1084.. Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-01-28 01:28:47 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-01-28 01:28:47 The network socket is connected. | 2014-01-28 01:28:47 The socket starting SSL connection. | 2014-01-28 01:28:47 SSL socket is now connected. | 2014-01-28 01:28:48 OEC FIX Trading session: Sending the Logon message. | 2014-01-28 01:28:48 Open E Cry FIX/FAST: Connected to trading server. | 2014-01-28 01:28:48 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-01-28 01:28:48 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-01-28 01:28:48 The network socket is connected. | 2014-01-28 01:28:48 OEC FAST Market Data session: Sending the Hello message. | 2014-01-28 01:28:48 OEC FAST Market Data session: Failed to decode a message. No template with ID: 1825163512. Bytes received: <C0>, followed by: <7D82, 4F45-4320-4641-5354-2050-7269-6365-F3, 6874-7470-3A2F-2F4F-7065-6E46-4153-542E-6F72-672F-4F70-656E-4641-5354-2F31-2EB1>. | 2014-01-28 01:28:48 OEC FAST Market Data session: Socket connection was closed without any logout messages sent or received. | 2014-01-28 01:28:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-28 01:28:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-28 01:28:48 OEC FIX Trading session: Sending a Logout message. | 2014-01-28 01:28:48 Disconnected from Open E Cry. | 2014-01-28 01:28:48 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-28 01:28:48 OEC FIX Trading session: Received a Logout message. | 2014-01-28 01:28:49 The SSL socket was shut down successfully. | 2014-01-28 01:28:49 OEC FIX Trading session: Logged out and disconnected. | 2014-01-28 01:28:49 |
[2014-01-28 07:51:46] |
Please go back to version 1078. You can download it from this page: http://www.sierrachart.com/index.php?l=doc/SCInstallerList.php We are having trouble with the FAST decoder for OEC. We are actively working on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
