Date/Time: Sat, 20 Jun 2026 22:22:41 +0000
Switching from AMP/CQG to SC Order Routing Service
View Count: 1082
| [2020-06-29 22:10:03] |
| User486568 - Posts: 11 |
I am already using the Denali data service and currently trade through CQG with AMP as my broker. One feature I like about CQG is that I get notifications on my phone for each execution. In addition, I can login to the CQG desktop to verify that I'm flat at the end of the day. Although it doesn't allow me to log into the web interface or phone app and stay connected to Sierrachart, it will disconnect me immediately once I login on another device. I'm interested in switching to your order routing service through TT and have a few questions: * Is there any extra notifications on order fills like CQG provides through an app (I assume not). * What features are available through the web interface, any order execution, position listing or charting? * Are you allowed to login in to the web interface while simultaneously logged in to Sierrachart? * If I lose ISP, will I be able to login to the web interface on my phone and flatten my position? I have a "sub-account" through AMP that allows me to trade a different strategy. Will this same concept work with SC Order Routing or is this something that is limited to CQG? Finally, if I would like to proceed, what is the process to switch over to using SC order routing and discontinue CQG? Would I end up paying all fees directly to SC or would AMP still collect any exchange or data fees? Thanks and if it's easier feel free to setup a call to discuss on the phone. |
| [2020-06-30 19:12:03] |
I can login to the CQG desktop to verify that I'm flat at the end of the day. This is no better than just simply reconnecting in Sierra Chart:File Menu: Procedure to Reconnect to the Data and Trade Servers 1. You can get SMS notifications by setting up an alert for order fills. Refer to: Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications) 2. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel this can also be used on a mobile phone in your browser. 3. Yes, you can use the web interface at any time and it has no impact on what is occurring on your Sierra Chart software. 4. Yes. 5. As long as you have AMP switch both the accounts, then you will be able to trade them both as you do now from Sierra Chart. 6. You would need to let AMP know to get you switched over and we will work with them to get everything done. You can either pay everything through AMP, or you can pay it directly to us. It is your choice. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-30 19:17:13
