Date/Time: Mon, 25 Nov 2024 09:45:46 +0000
SC: Can not find the file specified - f.e. - gpsvc.dll
View Count: 1733
[2014-01-28 06:22:52] |
User82722 - Posts: 18 |
I am using Dependency Wallker(SierraChart.exe) wanted to determine the composition of functions Sierra Charts. Depends showed me a lot of messages : "Can not find the file specified"(rus - Не удается найти указанный файл). I have installed on your computer Windows 7x64 SP1 license and am constantly doing its updates. Version of the Sierra Charts 1084, these same messages were in version 1081. Do I need to pay attention to what shows depends? Is there any way to remove these messages? Do I need additional software to work on my computer Sierra Charts ? Join image with the result of Dependency Wallker. |
Private File |
[2014-01-28 07:54:34] |
Are you having trouble running Sierra Chart?. We cannot help with what you see with dependency Walker. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-28 08:15:34] |
No, Sierra Charts works. But in this case, if any difficulties arise, I would think that this Sierra Charts:) Thanks, I wanted to know what professionals think about this. Best regards |
