Date/Time: Sat, 08 Feb 2025 04:42:13 +0000
DPL is off
View Count: 611
[2020-06-29 14:19:44] |
User160847 - Posts: 5 |
The DPL total in the trade window is way off...it's not giving the right total. Please help, thank you.
[2020-06-29 18:15:20] |
Refer to this page for help with this: Help With Daily Profit/Loss Value You are also running an older version of Sierra Chart. Please update as soon as possible: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
