Date/Time: Sun, 23 Feb 2025 08:26:13 +0000
[User Discussion] - Elgato Stream Deck for hot keys
View Count: 4850
[2020-06-29 12:38:27]
User563523 - Posts: 2
Hi- Trying to use the Elgato Stream Deck for hot keys with Sierra. Hot keys work fine from my keyboard and programmable Logitech gaming mouse but Sierra seems to not "see" anything at all from the Stream Deck.
The Stream Deck works just fine for hot keys on the same computer with both Ninjatrader and IBKR TWS as well as any other program I've tried to use it with. Any ideas?
Thanks!
[2020-07-08 15:15:12]
User441146 - Posts: 8
Any news ?
[2020-07-08 15:29:47]
jh4315 - Posts: 2
Resolved - Turns out the culprit was the fact that I'm using Input Director to control multiple computers with single keyboard/mouse. Works great and this is the first issue I've ever had. I was running Sierra Chart off one of the "slave" computers but also had the Stream Deck plugged into the "slave" computer. When I moved the Stream Deck to the "master" then it worked fine as far as hot keys for Sierra Chart. It did introduce yet another different problem but not with Sierra.
[2020-08-10 12:13:21]
Gianmarco - Posts: 10
i saw a perfect integration of the streamdeck here:
is there a possibility to implement somethng like that? does someone has a similar stuff already done?
thanks and regards
Gianmarco
[2020-08-29 13:57:15]
mazzy /| blast - Posts: 54
You talk about the ProRealTime integration ?
more attempts to recreate it
https://futures.io/traders-hideout/45980-stream-deck-elgato-ninjatrader8.html
Would be nice if some official integration was worked out for SC. Useful gear
Alternatives without interactive display on keys
http://www.keyboardtrader.com/keyboard.html
http://www.trademaster.co.uk/traderkeyboard.htm
Date Time Of Last Edit: 2020-08-29 13:58:39
[2020-08-29 14:48:54]
Here's one of the simple setups I use with Sierra. The "Next" button calls up different set of buttons. Works great.
imageimage000000.jpg / V - Attached On 2020-08-29 14:48:16 UTC - Size: 349.43 KB - 2197 views
[2020-08-29 21:12:35]
would you mind to share the preset?
[2021-02-11 21:47:14]
User894573 - Posts: 9
Stream Deck work for 2 days and now nothing, hot keys don't even work with SC, grrrr... Sure these is a shiny red button I push someplace that terminated something.
[2021-02-12 15:41:01]
jh4315 - Posts: 2
Make sure you have "Trading Keyboard Shortcuts Enabled" checked under the main "Trade" menu. If not, no hotkeys will work no matter what.
imagetradekeys.png / V - Attached On 2021-02-12 15:39:17 UTC - Size: 37.33 KB - 703 views
