Date/Time: Sat, 08 Feb 2025 06:22:37 +0000
ERROR AL CONECTAR CON RITHMIC
View Count: 581
[2020-06-29 11:46:52] |
User391530 - Posts: 2 |
HOLA ACTUALMENTE ESTOY USANDO DATOS PARA SIERRACHART CON AMP . QUIERO TAMBIEN CONECTARME CON RITHMIC Y NO ME PUEDO CONECTAR. EL ERROR QUE APARECE ES: Connection error message from service: Rithmic bridge need installing. To obtain in the bridge files. go to https://sierrachart.......ThreadiD-52647 Date Time 2020-06-29 12:54:34 |
[2020-06-29 18:49:00] |
Refer to the information here: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
