Date/Time: Sat, 08 Feb 2025 07:54:44 +0000
Setting up two broker connections
View Count: 1648
[2020-06-29 04:07:13] |
User169687 - Posts: 7 |
I would like to use SC from two different brokers: AMP for futures and Interactive brokers for forex and shares. Currently, I am using SC with AMP subscribed to Denali + TT + SC package 3. If I want to use SC with two different brokers can you please explain the steps to set it up. In addition, the data feed for forex and shares can come from Interactive Brokers or I should get the data feed from SC. Thanks. |
[2020-06-29 04:24:12] |
Sierra_Chart Engineering - Posts: 18338 |
The instructions for what you want to do are here: Using Multiple Data and Trading Services at the Same Time Sierra Chart does have a Forex data feed: Sierra Chart Real Time and Historical Forex and CFD Data Service And a data feed for US and European equities: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-29 05:22:08] |
[2020-07-01 12:05:02] |
I just unsubscribed from the data feed provided by AMP, since I would like to purchase package 5 directly from SC trading with AMP for futures and interactive brokers for forex and stocks. So, two brokers and two installations of SC where the CME data feed I will buy from SC, and the data from stocks and forex will be from Interactive brokers. Currently, I login in SC using the credentials provided by AMP. Should I create a new account within SC in order to buy SC package 5 and the data-feed from Denali CME directly from SC? Thanks. |
[2020-07-01 19:08:14] |
Yes you need your own direct Sierra Chart account. Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 04:29:57] |
I am activating package 5, order routing, and Denali Data feed for CME ($10.4). Before activation of the Denali Data feed for CME the following statement appear: " You must have a funded futures Trading account with one of the supported Trading Services and Sierra Chart must be connected to that account, to be able to use this exchange. Do *not* activate this exchange unless you have a funded futures trading account with one of the supported Trading Services because otherwise you will not receive real-time data with this particular exchange and Sierra Chart support will not be able to issue a refund." So I have a AMP funded account. This is a supported trading account (AMP) using the Denali Data feed? So can I use the Denali Data feed trading with AMP. |
[2020-07-02 05:26:39] |
Possibly. It really should be an TT account that uses the Sierra Chart Order Routing Service to be safe: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-02 11:52:52] |
User651232 - Posts: 6 |
I just submited two tickets for the Trading Account Assignment Request Form and the web-based trading panel activation with the user of this post. Can you please allow them. Thanks. |
[2020-07-03 12:57:39] |
SC Support - Posts: 1930 |
Hi User651232, we see that both of this tickets have now been resolved. Thank you
[2020-07-03 13:02:10] |
Thanks.
