Date/Time: Sat, 08 Feb 2025 05:13:31 +0000
Forex / CFD data
View Count: 626
[2020-06-29 02:59:42] |
User664285 - Posts: 11 |
Hi, what is required in order to see live forex and CFD data? I am currently with AMP+CME, when I go to Data/Trade Service Settings I see SC Data All Services is showing as Not enabled. Thanks. |
[2020-06-29 03:08:46] |
Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
