Date/Time: Sat, 08 Feb 2025 05:03:54 +0000
[User Discussion] - Strange artifacts in Study / Subgraphs & Ordering of inputs
View Count: 577
[2020-06-28 22:42:47] |
User972768 - Posts: 166 |
Hello Sierra Support, I have 2 quick questions about v2128 (not sure if they started with this version or before, I just have noticed them after last update): - In the Subgraphs tab of study settings there are strange artifacts behind check mark boxes (see attached screenshot) - Ordering of study input parameters now starts from 2 instead of 1 as it was before even if I use my_input.DisplayOrder = 1; Hope it is not too much troubles to correct. Thanks in advance |
[2020-06-28 23:07:05] |
There are multiple problems here. Your Sierra Chart account is expired and is not entitled to support. You are pointing out a garbage Microsoft operating system issue with dialogs. This is not our issue. And then you are pointing out a nonexistent issue regarding Input DisplayOrder. We do not know how you are coming to that conclusion and that is not within the scope of our support. We are not going to say more. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-28 23:08:43
