Date/Time: Thu, 09 Jan 2025 18:59:29 +0000
how to set Limit prices on SCT_ORDERTYPE_OCO_BUY_STOP_LIMIT_SELL_STOP_LIMIT
View Count: 1013
[2014-01-28 02:22:38] |
hairyMug - Posts: 31 |
The documentation only specifies how to set the first & second stop... Where do I set the limit prices for the two trades?? |
[2014-01-28 04:24:26] |
You cannot. The limit offset is set through the Set tab of the Trade Window for the chart the study is on.
[2016-08-09 21:42:35] |
@sstfrederik - Posts: 404 |
Can I set s_SCNewOrder::StopLimitOrderLimitOffset for setting the limit in this ordertype in ACSIL? thanks. adjusted post. Tested and it seems to work fine. Date Time Of Last Edit: 2016-08-10 00:27:59
[2016-08-10 06:22:47] |
The documentation explains that structure member: Automated Trading From an Advanced Custom Study: s_SCNewOrder Structure Members If it is not clear, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
