Date/Time: Mon, 25 Nov 2024 09:37:34 +0000
[User Discussion] - CCI
View Count: 2168
[2014-01-28 01:12:43]
User72642 - Posts: 6
Hi there,
I have recently subscribed to Sierra and I have some trouble creating this CCI setting on my chart, could you please send me the settings I have to use to replicate what I need? See attached pic
imagecci.jpg / V - Attached On 2014-01-28 01:12:26 UTC - Size: 26.08 KB - 453 views
[2014-01-28 01:52:51]
Sawtooth - Posts: 4120
Put 3 instances of the CCI study on the chart, set the Chart Region of all three to the same region, and set the Length of the 1st and 2nd instances to 45 and the Length of the 3rd instance to 6.
1) To get the histogram of the 45 CCI, set the Draw Style of the 1st instance to Bar and the Auto Coloring to Based on +/-.
2) To get the line on the 45 CCI histogram, set the Draw Style of the 2nd instance to Line.
3) To get the line of the 6 CCI, set the Draw Style of the 3rd instance to Line.
[2014-01-28 02:10:05]
Thank you so much Tom.
Would like to ask you if it's possible to see the daily traded volume updated in real time either or the DOM or on the chart?
[2014-01-28 02:28:01]
It's possible with the Spreadsheet Study study and the Text Display For Study study.
1) Add the Spreadsheet Study study,
-check Hide Study.
-give it a name in the Spreadsheet Name field
-set the Number of Formula Columns to 10
-press OK and OK
-on the spreadsheet, put this in cell K3:
=$J$20
2) Add the Text Display For Study study
-Set the Study and Subgraph to Display to the spreadsheet study and K(SG1)
[2014-01-28 02:49:35]
Perfect, Thank you so much and have a wonderful night!!!
