Date/Time: Sat, 08 Feb 2025 04:42:13 +0000
Graphic Settings chart not saved
View Count: 705
[2020-06-27 21:30:56] |
nosast - Posts: 312 |
After I updated to 2127 but still present in 2128 there seems to be an issue that graphic settings of my DOM (not global) are always reverting back and ignore the colors I set up. For example I change the Last Trade Price box and Trade DOM Text to my desired color and after restart they are back to default. |
[2020-06-28 02:18:54] |
Refer to: Trade and Chart DOM Color Settings Changes Also we observed no issue in version 2128. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-28 17:52:20] |
Seems to work once I re-installed 2128. Only difference I see now is that the background of the column with recent trades is not colored to the edge. See attached.
[2020-06-29 05:37:19] |
Sierra_Chart Engineering - Posts: 18338 |
This is resolved in 2129.
