Date/Time: Sat, 08 Feb 2025 04:53:07 +0000
Draw Style Fill Top and Fill Bottom at the same time does not work
View Count: 829
[2020-06-27 21:03:29] |
User128888 - Posts: 30 |
Hi, I'm trying to use the bollinger band and changing the draw style to fill the top and fill the bottom at the same time. If I use the same type of draw style to fill the top and bottom, it doesn't work as expected. If I pick different types of fills for the top and bottom, then it works as expected. Attached are screenshots. Is this a bug or just how it is? I'm using a workaround of using 2 studies and one fills the top and one fills the bottom to get it how I want it to look. Thanks. |
[2020-06-28 03:14:34] |
The problem is your expectation is incorrect. The functionality works correctly. Refer to the documentation for those particular Draw Styles.
[2020-06-28 10:41:49] |
ok got it. thank you. found it at here: Chart Studies: Notes about Top and Bottom Draw Style Pairs it was designed that way for people to fill the space between two subgraphs. |
[2020-06-29 05:36:46] |
Sierra_Chart Engineering - Posts: 18338 |
Yes.
