Date/Time: Fri, 14 Mar 2025 12:22:10 +0000
TPO Study Question
View Count: 896
[2020-06-27 03:05:05]
Sirius Trader - Posts: 2
Edit: I figured how to get separate RTH and ETH sessions. I would like the letters in the overnight session blocks to restart with a lower case a. As it is now, they appear to be just a continuation of the RTH session.
Is this possible?
had a bit of time to look into it last night. At first glance it appears this could work out. I explored the absolute myriad of options for the TPO study, but I didn't see exactly what I was looking for; or maybe I did and just didn't realize it.
I would like to see the RTH and ETH sessions side-by-side on the chart. For example, if I am looking at three 24 hour periods of data, I would like to see 6 profiles on the chart:
ETH-RTH-ETH-RTH-ETH-RTH
Is this possible?
Date Time Of Last Edit: 2020-06-27 23:48:12
[2020-06-29 10:24:46]
Refer to this section about this:
Time Price Opportunity (TPO) Profile Charts: Displaying Separate Profiles for Day and Evening Sessions
And refer to:
Time Price Opportunity (TPO) Profile Charts: TPO Letter Codes and Letter Customization
[2024-12-22 16:10:40]
User836264 - Posts: 6
Hello. I currently have a TPO set up with 3 custom intraday sessions all with a 1 second gap per session (e.g Session 1 ends at 07:59 and Session 2 starts at 08:00). I have my "Letters always start at primary session start times".
My requirement is that whenever Intraday Session 1 ends, I want session 2 to start at Letter A all over again. For example. At 07:59, if Intraday session 1 is on the letter Q, I want session 2 to start on A. Currently, if session 1 ends on Q, Session 2 starts on R.
Is there something I am possibly missing?
[2024-12-23 15:13:01]
John - SC Support - Posts: 38653
The resetting of the letters only applies to the Session Times as set in the Chart Settings. It does not apply to the "Custom Intraday Sessions".
We have noted this as a feature request. We can not say, however, when we would get to any particular request.
[2024-12-23 15:19:00]
Sierra_Chart Engineering - Posts: 18778
You should be able to accomplish this by changing the TPO letter sequence:
And within that sequence use the letter A and the following letters three times. You just need to determine, at what point in the sequence you need to start A again.
Date Time Of Last Edit: 2024-12-23 15:20:27
