Date/Time: Sat, 08 Feb 2025 05:05:19 +0000
SC heatmap hotkey request
View Count: 620
[2020-06-26 16:09:55] |
User389151 - Posts: 37 |
Hi I'm looking for hotkey feature in sierrachart heatmap where it changes a setting of "Market Depth Historical Graph" study. I want to change input value of "Graph Only Quantities Greater Or Equal to". 2 hotkeys that increase or decrease this value by like 10. Is this feature available or do i need to find programmer to create this hotkey feature? thanks
[2020-06-26 19:34:28] |
You would need to custom program this: Advanced Custom Study Interface and Language (ACSIL) It is possible for an ACSIL study to change Study Input values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 19:35:09
