Date/Time: Sat, 08 Feb 2025 02:46:12 +0000
Daily Net Loss Trigger Value
View Count: 606
[2020-06-25 16:18:09] |
TT46 - Posts: 10 |
Does the Daily Net Loss Trigger Value correspond to how I display my PnL? If i want a day stop limit of -40 points, do i use -40 for the loss trigger value?
[2020-06-26 05:13:52] |
No. It is always in Currency. Refer to the following for information on how this is handled in the case of multiple currencies: Global Profit/Loss Management: Handling Multiple Currencies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
