Date/Time: Sat, 08 Feb 2025 02:55:02 +0000
Gaps in charts
View Count: 554
[2020-06-25 14:44:57] |
User80177 - Posts: 29 |
Hi, Since updating to SC version 2125 a few days ago, I've noticed gaps in charts for futures symbols GC, DAX, CL with data from Interactivebrokers. This occurs when SC is launched and sometimes after "Delete and Download Data" was executed. The "Delete and Download Data" action seems to be taking much longer than usual. IB forex crosses such as USD/AUD is OK. Charts with data from Denali Exchange are OK. Can you pls advise? Thanks. |
[2020-06-25 18:21:12] |
We do not give support for Interactive Brokers Data issues. You would need to ask them about this. You will need to use the Sierra Chart data feeds for market data for those other exchanges. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart The "Delete and Download Data" action seems to be taking much longer than usual. Yes the Interactive Brokers system is very slow.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-25 18:22:05
