Date/Time: Sat, 08 Feb 2025 03:13:51 +0000
Calculate Same as Real Time
View Count: 787
[2020-06-25 13:19:33] |
User355030 - Posts: 163 |
What is the difference when using "Calculate Same as Real Time" in replay mode?
[2020-06-26 05:02:11] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayMode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
