Date/Time: Sat, 08 Feb 2025 03:11:14 +0000
Replay imported data
View Count: 499
[2020-06-24 17:29:35] |
User239984 - Posts: 8 |
Hi, when I import tick data with Bib&Ask volumes and numbers of trades, does SC use this data to get the actual bid and ask prices when replaying the chart? Thank you! |
[2020-06-24 19:14:19] |
No.
