Date/Time: Sat, 08 Feb 2025 03:03:21 +0000
Spreadsheet Study incorrectly displaces left
View Count: 553
[2020-06-24 15:44:36] |
User299107 - Posts: 58 |
Hi guys, firstly Well Done with Sierra! The more I use it, the more I like it. My experience with other software has always been the opposite of this and I end up disappointed. Not so with Sierra - stable, robust, minimal lag, customizable = FANTASTIC. After 15 years, software I can rely upon = YES! The current situation is that my spreadsheet study begins the day displaying perfectly with price, then after a few mins it shifts and prints 7 bars left of where it should be. I don't have it set to displace and chart is not set to independent (price and study move together). If I recalculate study, it goes back to perfect alignment.... until it doesn't again. Any ideas? Eliza |
[2020-06-24 19:24:06] |
It is hard to say what the problem is unless we see exactly the study configuration but it might be a calculation order issue: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-24 19:39:36] |
changed the Studies ORDER and all good - thanks again
